  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha Fast n Furious party ..... i'll have little demin shorts on so i'll fit in well all i need to have is some traffic cones to block off the street so aidwin can have a grudge race with the Silvia guys ;)
haha take pauls spare tyre out of boot .... fill the well with ice .... add beer ..... bingo instant esky :) :)
theres alcohol ...... i need to appoint a "Make sure Lauren does nothing stupid" person!! :)
Should be great fun .... hardly wait. In reality i'll probably be bored after the first half day but for now im seeing it as one giant party.
Lee starts at 10am.
