  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
yea thats the spirit Niz, its a giant weekend party
*niz turns up with glowsticks and covered in glitter* :rave:
haha :)
Hey Metros City apparently have a stage set up there and we all know how much i love their stage hehe
Lee yeah thats usually where i like to be at 10am!!
For sure Aidwin :) ..... staggering promo girl that smells of alcohol not a good idea haha .... nah should have a good time ..... anyone got a camera!
Alcohol powered car reminds me of that episode of the Simpsons ... haha :) Dan but Av Gas is sooo yummy .... just needs a dash of lime :)
Aidwin my car doesnt touch the soil in Northbridge either ..... i cant believe you walk along the streets and theres all these Skylines and drunken people are usually leaninig up against etc .... i cant relax and have a good time if i leave my car in a place like that - i get paranoid.
morning paranoid androids...
so you're paranoid about someone leaning on your car, but if someone comes through a red light and smashes you - let it ride?
haha
aidwin - I'll volunteer to drive your car up and down the freeway for you/ with you if you can get it ready in time..
*burP*
haha Dan :)
Yeah i had someone in another shitbox Laser wave at me ...... such an exclusive group i now belong to :)
On the way home from gym drove past the Panel Beaters but couldnt see my baby ..... in underground carpark they have there.
Alex .... that wasnt my fault that was just being at the wrong place at wrong time .... if i park it in Northbridge then i get what i deserve i might as well put flashing neon lights up - please come vandalise me.
As for the fuel cap no mines got a green sticker that says Mitsubishi Z (say what?) premium unleaded.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
