  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah lucks on his side!!
You saw me lurking haha :D
im a grumble bum today! Aidwin - do your parents meddle?? like they tell you your an adult and to deal with it when they want but the next thing u know they have all your bills strewn all over the bench top that they got outta your room ..... why they were in there in the first place! some lame excuse not knowing where i was staying yesterday looking for my backpack ..... weird i told them i was comming home even sent them a SMS!! And they are stressing over something thats my problem - plus i hate my privacy been invaded!
thought you did have your own place aidwin :confused: yeah well they made peace pretty quickly but they either want to treat me like a child or an adult .... one or the other .... they seem to switch their minds quite often.
Mel's not happy with her housemates so maybe her n i should find our own pad.
