  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi Danver, No, not exceptionally long, but I can see the point from a spectator stand point that the 4WD cars take a long time. I think you guys did a great job, if some of the MOGWA guys with phuck-all power had run on the Saturday then there wouldn't have been the rush at the end.
http://news.ninemsn.com.au/Entertainment/s...story_52516.asp
Some of the 250,000 who have visited the site during his fast have come up with increasingly inventive ways to taunt or unsettle Blaine such as using a remote-control model helicopter to dangle a cheeseburger in front of the starving magician.
HAHAHAHAHAHAHA
