  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
stoopid work
Guy: Lauren what do you like to do as an xmas function?
Me: I wont be around my contract runs out this month.
Guy: We'll have to make sure your still around
Me: *bashes head on wall repeatedly*
can't you people just let me gooooooo! its like alcatraz ..... once your in theres no escape! But he doesnt make the decisions who gets voted off the island anyway.
"teGan ( mailto:[email protected] ) has reported this post:
http://www.skylinesaustralia.com/forums/sh...7026#post497026
This is part of this thread:
Clear Indicators
http://www.skylinesaustralia.com/forums/sh...?threadid=23183
This is the reason that the user gave:
i want those indicators how can i get them??
This message has been sent to all moderators of this forum, or all administrators if there are no moderators."
My reply was:
"Hey TeGan i take it ure new to these boards. Welcome
The "report this post to a moderator" button is specifically for use by people who find the content of a thread to be insulting derogatory or go against the rules of the forum.
If you wish to find some clear tail lights (which i personally would touch witha 10ft barge pole) then i suggest u post in the thread asking other people participating in the discussion where you can find them. It also helps if you include the area you are in so people can tell you what is close.
Cheers
Shaun C"
What the hell? do ppl think the mods are aphone book?
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
