  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
stoopid work
Guy: Lauren what do you like to do as an xmas function?
Me: I wont be around my contract runs out this month.
Guy: We'll have to make sure your still around
Me: *bashes head on wall repeatedly*
can't you people just let me gooooooo! its like alcatraz ..... once your in theres no escape! But he doesnt make the decisions who gets voted off the island anyway.
"teGan ( mailto:[email protected] ) has reported this post:
http://www.skylinesaustralia.com/forums/sh...7026#post497026
This is part of this thread:
Clear Indicators
http://www.skylinesaustralia.com/forums/sh...?threadid=23183
This is the reason that the user gave:
i want those indicators how can i get them??
This message has been sent to all moderators of this forum, or all administrators if there are no moderators."
My reply was:
"Hey TeGan i take it ure new to these boards. Welcome
The "report this post to a moderator" button is specifically for use by people who find the content of a thread to be insulting derogatory or go against the rules of the forum.
If you wish to find some clear tail lights (which i personally would touch witha 10ft barge pole) then i suggest u post in the thread asking other people participating in the discussion where you can find them. It also helps if you include the area you are in so people can tell you what is close.
Cheers
Shaun C"
What the hell? do ppl think the mods are aphone book?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
