  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
:) im coming to work today ..... get onto Abernethy Rd and 2 Skylines (both of which is suspect are NA ... silver one definately was) come zooming past me ...... i kept up as best as possible BUT I WANT MY CAR BACK ;) one looked very similar to mine - Black GTR kit. WAAAAAAAHHHHHHHHHHH!!
Dad gets home and goes do you want the good news or the bad news? im let me guess "The good news is you've been the hunter of the family and bought home dinner (mums away) and the bad news is Pas has promised me the car next week now" I was right! Dad went and saw it yesterday and its been there a MONTH and they are just discovering problems in fixing it now!! :cheers: ..... dad goes "Have you ordered a new indicator?" mines smashed to smitherines and the panel beater goes "Oh is that smashed is it?" :wave: Im really pissed off and ive had enough!
yeah they should do Aidwin .... thanks just keep them on standby for now - i would like these lazy barsteds to source some themselves ..... they dont deserve for me to make things easy for them!!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
