yeah well i was trying the mind over matter approach paul but you just shot that idea down ;) haha ..... yeah i know ..... parents huge minus.... lack of freedom minus ...... free rent, free internet, heated pool and spa and pets allowed is a huge plus tho ....... its a lose lose situation stay or go but i think i'll just save and start buying bits n pieces and get myself organised ;)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Morning yall. Not a good 1 though.
So im lying in bed last nite and i hear a car alarm go off. I figure since the4 parents have friends around its gonna be one of them drunkenly stuffing up and making theirs go off.
I get up in the morning and hit the immobiliser when the key is in theon position as u usually do. The engine cranks over but it wont fire :confused: i look at the little batt, parkbrake lights etc and they are all off. The imobiliser is clicking on and off indicators flashing but no dice. I keep cranking it like the moron i am then get out, the fuse in the immobiliser is fine. I disconnect the batt and push the brake for a bit which only reset my clock and didnt do much else.
Any ideas cause i hate paying sparkys
i want pillar mount .... you know the one that fits on the pillar in nice casing ...... i dont want this huge dial sticking out in the middle of god knows where ...... one like yours paul.
But also saying that i dont want to spend a ridiculous amount on a phucking gauge!
Damn Boosty!! ;)
Paul no rush - might as well leave it til i get the veilside on and the car is once again fulltime mine!! and no i havent seriously started job hunting yet.
Aidiwn ..... you need intercooler etc to safely crank up the Boost .... which i dont have .......yet ;)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
