  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it was although with EBC the gap is narrowing! ZX is real lagging .... so im thinking maybe an aftermarket turbs went on it. The guy that owned it had money to burn .... has has the sweetest R33 now ... aftermarket turbs n motec Engine management has gone into that. The Zx he even installed a sensor the beeps when your brake pads are low.
