  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yep you were :)
I take inconsideration a lot of what my mechanic says etc but i dont see it as gospel .... the only way to find out if a product is good for your car is to talk to the people that have had the same set-up with the same type of car as you have :) Otherwise its a lot of money to spend on a product that you may be disappointed with.
:) u should see my office .... i had it printing from wrong tray and it was spittting out 100 plus pages onto the floor of my office .... so now ive just got a pile of papers on floor!
Government paid my temp agency $1,300 to have me here this week (not that i did a lot) its so high because everything over 38 hours for a temp is overtime and i do a 42.5 hour week here :) so ive got 1.5 and double time included :)
