  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
my second excursion in the chair.. the 1st one took 45 mins cause it was on it's side.. the other two on this second excursion were heaps quicker.. which was all good cause i don't think i could have handled it otherwise...
hehe I went even further and got put to sleep for mine :P
Half my problem is that I dont know exactly what I need.... I just know its time to replace my worn out items so I may as well put on a complete new upgraded set of stoppers on my car...
Yeh been there, u get gas too?
Man ure teeth are coming in late, ure 4 years my senior and mine came through like 4 years ago.
How the sound of the cracking and snaping of stuff when ure teeth get pulled man its harsh, ill never forget that.
I have spent like a total of 200hrs in the chair due to my two front teeth being fake, braces and various other fun procedures.
me gettin some dba slotted rotors but i have to wait for the machining run over east to be finished cause there's none in stock for r33's.. should land in perth by the 18th...
is $560 cheap for a front pair?
I think ure allowed 6 doses a day. but u can also take 6 doses of nurofen a day cause its not using paracetamol. So thats 1 tablet an hour 24hrs a day. oooohhh yeh, take me to cloud nine baby.
Dont forget ure savacol and warm salty water.
nah - no gas... almost passed out yesterday after he ripped the two out tho... i don't think i'll be forgetting it in a hurry either... man - sounds like dentists have done a number on you! I'd rather do almost anything than goto a dentist...
Ahh u get used to it after a while. In year 8 i went to the dentist once a week every week for like a year. ahh good ol root canal.
My two front teeth are screwed into my jawbone, so they took a bit of work.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
