  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I want this car
1989 Twin Turbo Callaway Aerobody Corvette #10
Callaway Twin Turbo Engine
Twin Garrett turbochargers with integral wastegates
Twin front mounted oversized ram-air Spearco charge air coolers
Special dual inlet air induction system with high flow K&N air filters
Special 3" dia. Free flow Turbo exhaust system with crossover for export
Stainless steel 3" diameter inlet 5" can Supertrapp mufflers
Heavy duty cooling system with aluminium Griffin racing radiator
Alfa-laval 10 plate oil to water engine oil cooler
Accel/dfi engine management system with Callaway calibration
Racing Electronic Services accel/DFI-GM E.C.U. adaptor system
Bosch injectors, 51.24 PSI at 60 lbs of fuel pressure
Callaway prototype hood with charge-cooler air extractor openings
Callaway prototype Ram-Air high flow capacity nose
Callaway carbon fiber "twist" air inlet
Callaway carbon fiber charge cooler extractor ducts
L-98 engine block, 4 bolt main caps, splayed-bolt style
Michigan engine bearings
Forged gas nitrided crankshaft, 60Rc journal hardness
Proprietary cosworth forged pistons, .006" O/S
Plasma moly ring package
Carillo connecting rods, 5.7 centers, matched and balanced
Experimental short runner fuel injection inlet manifold
High volume oil pump
Hydraulic roller lifters
Specially hardened distributor drive gear
Dry sump pump for turbo oil scavenge
Oversize stainless steel inlet (2.020) and exhaust (1.600) valves
Corvette L-98 cylinder heads killer ports, gas flowed and decked
Dymag 17.0 X 9.5" wheels
Goodyear P275/40 zr 17 tires
Callaway fuel and manufacturer's plaques
Refinish intake manifold/tuned port injection with black wrinkle finish
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
