  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thanks hun :cuddle: just need it ....its just a headcold so i shouldnt be able to pass it onto you i think - sinus's n all that crap.... i dont have a cough or anything .... just a headache and achy bones ... i feel like n old woman :D
