  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i remember the good old days in tafe doing info tech learning to hack a password from a pay site. 2 friends got banned from their ISP for it, no legal dramas or fines though which was good.
so paul just the goat then?
dude no dramas on the bov, its the insurance mate.
I will sell the car to you UBER cheap, if you can get the insurance.
tame this!!!
** Posted: Today at 8:07 am
# : BBlorenzo : xYXcrEu8TTqD Proxy used: 210.220.73.9:80
# : BBmanuel99 : PHoIUOFtzgHk Proxy used: 193.251.169.170:80
# : BBmasena-2 : WkHxQ2g7i5NZ Proxy used: 193.251.169.171:80
# : BBmeuchelmorder : 76dp15KaLqtd Proxy used: 194.126.30.138:3128
# : BBoakville : 33IkHVaWRcQO Proxy used: 81.40.35.0:80
# : BBoninoken : YA6TsGfJwG9S Proxy used: 81.40.9.255:80
# : BBPSolace : q5aG2tHl1EPq Proxy used: 211.46.218.97:8080
# : BBpoolboy2310 : Ok6TXUtSUapj Proxy used: 210.95.49.3:8080
# : BBprickolini : reMr3Yifthjm Proxy used: 194.132.65.254:80
# : BBprince37 : UlJQwJgfl2HZ Proxy used: 211.57.78.2:8080
i dont pay much at all for mine, but I am hooked up.
if more people got to me before the friggin fraudulent claim we had with a certain R34 that used to be on these forums then all would still be fine and even 13_devil would have insurance.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
