  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well yeah i need it fixed soon otherwise you can come live here and listen to my parents whinging ok! .... plus im not happy that my car can run outta fuel whenever it pleases i really dont need the stress of it - i just want it to be normal how it was before .... noone else has these problems withthe Bosch pump!
well if i knew i was going to have these probs i would just get a standard one .... its just time is not something you have and i would liek it done sometime before the new year :D my parents are really hassling me about it and now dads giving me shit how i shouldve just left it alone and they shouldnt of bought me the R33 and all this shit :)
well i dont need it phucked on friday cos i have work!! and i woul dleave it til next week but i have work on Wednesday ..... so yeah.
Newsflash .... my parents OWN my car and the fact i live with them they kinda know when somethings wrong with it :rolleyes:
yeah but if it plays up it'll be friday
"yeah sorry cant make it to work cos my car is p-h-u-c-k-e-d" ..... not liek i dont need money at the moment either :rolleyes:
anyway see ya have a good day at work.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
