We are at a little place in South australia called Streaky bay. Made 2050k in 2 days, not bad i reckon. End of the line is Brisbane but we have a suite booked at crown towers for teh 5th. Should be good i reckon. Killed a bird today, my first roadkill ever :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
today was sooo fuuny, i was driving home in the line, and at the lights a P plater pull up next to me is some car and i look and him and smile and they both smile back at me (2 guyz in the car) then one of the guy go shittttt, you must be a good Learner to be driving this car.
when the light turn green i gave it alittle so they heard the loud psssssssssssssss! they pull up night 2 me and go "WOW!!!"
actually you get a lot of attention in the car .... unfortunately by mostly old rough looking guys. and the attention i get in my car is from young little kids .... the most attention i get from my own age group is when im driving a shit box.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
