  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aww man, if farking JAP
okay first plan of action
check with whom ever it was who turned it into a clock concealed timer cos he has obviously managed to install it with jap instruction.
second, why are these boost gauges dead
ecu is not in the boot
its in the passenger kick panel
under the glove box and to your left, just under the factory flare in that panel
it comes off quite simply and then the ecu sits there.
i dont see why the gauges both died at the same time, because if the dash one is electronic then yeah maybe a wire problem, but if the blitz one is dead thats weird cos its a mechanical gauge.
the vacuum line is all that is involved in making it move.
which means the car is not providing a reading to the vacuum line, which means the line must not be connected.
i dont get any other explanation
I think the vacuum hose blew off the back of the gauge,
that would make more sense.
Especially if both the gauges died
i just dont get it hey
if its not resolved by the weekend. i will come round if thats cool. and maybe we can go through the wires and the lines.
yeah riaz, good idea - my dad was getting worried didnt know wat else was going 2 **** up but i told him it was alright and i would get it fix.
And today i notic the chick factory to the skyline. after work my mates rock up with some girls that work at macca's and one ask me to take her home and smile at me like she wanna 2 hook up this was wired cuz she never talk 2 me at work at all.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
