  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aww man, if farking JAP
okay first plan of action
check with whom ever it was who turned it into a clock concealed timer cos he has obviously managed to install it with jap instruction.
second, why are these boost gauges dead
ecu is not in the boot
its in the passenger kick panel
under the glove box and to your left, just under the factory flare in that panel
it comes off quite simply and then the ecu sits there.
i dont see why the gauges both died at the same time, because if the dash one is electronic then yeah maybe a wire problem, but if the blitz one is dead thats weird cos its a mechanical gauge.
the vacuum line is all that is involved in making it move.
which means the car is not providing a reading to the vacuum line, which means the line must not be connected.
i dont get any other explanation
I think the vacuum hose blew off the back of the gauge,
that would make more sense.
Especially if both the gauges died
i just dont get it hey
if its not resolved by the weekend. i will come round if thats cool. and maybe we can go through the wires and the lines.
yeah riaz, good idea - my dad was getting worried didnt know wat else was going 2 **** up but i told him it was alright and i would get it fix.
And today i notic the chick factory to the skyline. after work my mates rock up with some girls that work at macca's and one ask me to take her home and smile at me like she wanna 2 hook up this was wired cuz she never talk 2 me at work at all.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
