  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what lights problem ..... im more of a shit stirrer than an person that sorts out technical problems.
Day well this guy (client) came in today and he asked me how my New Years was ..... then after knowing him 15mins he proceeded to tell me how he went to Perth Cup with a Stripper that finished work at 6am .... and the love of his life that has a 10yr old that lives in Bunbury found out so now she's told him t shove it .... Wha tha? i didnt ask for his phucking life story!!
saw it Mike .... cant help ya mate .... but you get used to the fact that theres never a time where your car is running perfectly .... always something you need to fix.
joe - good to be back at work eh?
odo stopped ticking over
overfuelling like a bitch
brakes squeel terribly
front spoiler has become unsealed n loose in passenger side again
my drivers side rear rim has been scraped
the centre console lid is broken
when it idles it splutters after a while but all i get is ... well its leaking somewhere but we dont know where.
its well overdue for service .... been like 8 months since last service
its fuel warning light plays disco and flashes on n off when you first fill up tank.
Would you like me to go on ..... or do you get the picture!
ok problems
1: Park Lights Broken
2: Brake Light (in S2 wing) Broken
3: Fog lights Broken
4: Front Bar Crack
5:Crack In Brake Lights
6:Front Headlights clips broken
7:Car Running Lean
8:Need better alarm
9: Need stock springs install
10: Sub need 2 be fix in
hmm that is all i can think of for now
well i dont even have an alarm :D
and my amp is roaming around the back of my car cos strahtfield did a shit job of mounting it .... subs all roaming around the back freely cos paul had to disconnect it all to get to fuel pump.
Missing my engine cover too paul! :mad:
and all those light problem hould be counted as one :mad:
PS - you car is not running lean you havent even put it on dyno and plus your running stock boost.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
