hey riaz, im back
Yeah i know about the number kms ect but i dont really care just wanna get it working some time in the future for now, I want to get my headlights fix, and back light fix, along wit the brake light in the Wing?
Did u find out about the part? i had alook at tring 2 open it but it doesnt look like it is glue togother and i didnt want to crack it
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
its too hard to explain over the phone so you gotta take it to autoworx along with the LED unit, which unscrews from the wing. and then you gotta heat it up and then open it,
and then reseal with sikaflex etc. but thats the cheapest way to fix it as they are expensive
not to sure yet, as im still looking at what to get, ken can get me a set of aus spec coilover for around $2,000, but i might just get aset of HKS HyperMax II as they around only $1,700 and with the shipping/gts ect it should only be alittle more than the aus spec ones, but im also going 2 look at the apexi ones 2
hmm so your p roject will basically be $1000 for the car $4000 for body repairs $2000 for spray
$2000 for Sr20
$5000 of labour and small things required for conversion
$1200 for wheels
yeah you will want to be driving that on the weekend from the look of it.
and your line will still beat it.
I think coilovers are major overkill especially when paying new prices for them,
paul might even have a shock sitting round for like $30 thats a better way to go.
i mean with your project car and all. Do you own mcdonalds by any chance??
your front lights arent in place right because they have been sikaflexed in place but whoever installed it originally.
so if you want to heat it up or cut them out and then mount them again, feel free, but i can tell you know its alot of messing around.
i would have done it, but its too much fiddling and also wiring the lights etc was all too much to do after all the stuff i did to make it presentable and clean and neat
riaz, its a project car which means it doesnt have 2 be ready untill along time away. I want to get the coilover 1st before anything else.
Im looking to get the a86 in about 3months do alot of the work myself and learn on the car.
I just wanna get the coilovers, with hieght adj. so it kind of solve 2problems
$2000 isnt much for u?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
