  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
GTR headlights are the same design you will just need to check teh mounts as the GTR has morte parts mounted in the front so the plastic components will be different litle...............
But all in all they should be the same. The factory would have to produce two sets for the same look and body, that would just be a waste of money.So I think they would have to be the same.
Mikey ive heard Hybrid works quite well ..... best to actually talk to people that have one in their car tho - if you serch the forums i think theres been a couple of threads started about them before :)
Guy at work has been taking a lot!! i dont know why ... but he's given them to me on a disk
Yeah a face only a mother could love.
Anyway im outta here for lunch cya! probably wont be back til late this arvo cos ive got so much work to do!
shit sorry 2 hear that sexzila, i cant belived no one helped you like niz, that is bs a person just lieing on the side of the road not moving next 2 there car:mad: that shit really pisses me off, if i was there i would have stop and help you.
and the no police that is just ****ed :), i remember when i always got bash by 2 big guys for $5, but i ended up giving them the money and then they walk away, went to the police station in morely no one was there 1 :)
sexzila, its just getting fu cking crazy, im 2 scaried 2 leave my car in any parking spot for along time (as i dont have my alarm yet) but im also scaried 2 just go walking with my mate around morley, His house is like 5mins away from the galleria but it just isnt safe 2 walk there anymore he has been done like 2times by some people mugging him
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
