  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahahahaahhah rep, i like that idea :)
aidwin, thanks dude for looking out 4 me, yeah i am kind of attached 2 her, she blows my mind in everyway , she is my perfect match. And it is the same for her :)
Your only 16 11/12 , how many babes have you been out with and wait to you start clubbing/partaying etc
We will ask again in 12mths ;);)
Cheers
Ken
after 16th.not on the dot lol
ken- yea pwpft got it on the way back from free-O. its jap so it has to be defected
Well he got it on , so he should get it off. :Bang:
He doesn't have to be driving your car around. I think he just is :inlove: with it rather than his gay winged monster.
Cheers
Ken
Ken, umm about 10+ i think
Emily
Emma
Lauren
Rebecca
Hailey (was 17 :))
Claudia
Mel
Steff
Alot of hooking up with random chicks at underage clubs *this was in the years of 01/02*
You sure that wasn't a random hookers , not hooking up with randoms... :)
Cheers
Ken
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
