  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sill little kids harrassing me in shopping centre carpark today ...... its like a new generation of mikey's waiting to happen!! "Wow you drive the most awesome car" .... little brat with bike a little too close to my paintwork .... "See that car over there" ...points to dodgy faded green R30 ... "thats a Skyline too" .... "but yours is the best" ...... that was all cool until that started hassling me for change ...."with a car like that you have to have some kinda change" ......me:"Look kid when you get older and you own a car like this - you'll no why i dont have any change!!"
Why do i always get blame for everything :confused:
i'm bright ****ing red.
*mental note to self* put sunscreen on BEFORE you go visit your g/f's horses in whoop whoop when there is no shade*
At least I had fun tormenting LOTS of ants. Found some MASSIVE nests and just annoyed the **** out of them.
Think I'll take a magnifying glass next time :mad:
LOL i do that - we have bees that fall into our pool ..... and so if you take them out an dput them on pavement they just fly into pool again :mad: so i take them out n put them on an ant nest nearby and watch all these little ants attack the bee.
I reckon I had about 2000 ants at the first nest, and I would stick a stick down their main hole, you'd get another 1000 ants come straight out and form like a manhole cover over the hole and about 100 ants climb up the stick and attack it, then I pissed on them and a heap died, it was cool.
The second nest started off with about 10 bullants and I poked the hole and another 50 or so came out, then I fully mashed it up and about 200 came out, so I pissed on them and some of them died too.
Bet you've never done THAT niz :mad:
I'd hate to be a chick (except you'd get to do all kinds of cool things to yourself) and have to piss over an ants nest, cause you'd have to squat RIGHT over it .. At least I can stand back and laugh and not have the little buggers crawl up my feet/legs :mad:
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
