  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
this is what he got in
BANZAI MOTOR SPORTS
ITEMS IN STOCK:
•HKS GT2530 BB TURBO FOR RB20/25 GOOD CONDITION 320HP $1,650
•HKS GT2530 BB TURBO BRAND NEW 320HP $2,300
HKS T3G NON BB TURBO TO SUITE RB20/25 RATED SAME SIZE AS GT2530 $800
•HKS T300S (T4 STYLE FLANGE) GOOD FOR 450-500HP SUIT 2LITRES OR UP $1,300
•HKS T04R KIT FOR RB20/25 650HP KIT INCLUDES(HKS T04R TURBO, HKS CAST LOW MOUNT MANIFOLD, HKS EXTERNAL WASTEGATE, GREDDY TYPE R BOV AND SOME ADDITIONAL PIPING)
$2,600
•2X HKS GT2835R TURBO’S BY THEMSELVES EXTERNAL TYPE
$3,500 FOR PAIR OR $1,800 EACH
•HKS SQV NEW TYPE BOV KIT FOR RB20 GOOD CONDITION $310
•HKS USED T04R TURBO BY ITSELF 650HP RATING $2,000
•HKS NEAR NEW STEP II GTR CAMS 264IN 272OUT $800
•HKS USED MUCHROOM FILTER $90
•APEXI EL SERIES II BOOST GAUGE 60MM MECHANICAL NEW $220
•BLITZ SUPER SOUND BOV USED, KIT FOR S13 SR20 AND CA18 $220
•GREDDY TYPE R RACING BOV USED KIT FOR GTR GOOD CONDITION $350
•GREDDY V-SPL INTERCOOLER KIT NEW FOR S13 $1,550
•S14 STANDARD JAP SPEC BALL BEARING TURBO AWSOME ON CA18 OR S13 SR20 $800
•1JZ 2X STANDARD CT12 TURBO’S CHEAP!!!!! $400
•6X STANDARD R34 GTR INJECTORS, GOOD UPGRADE ON CA18 ETC $650
•NEW Z32 AIR FLOW METRE $450
•S13 STANDARD SR20 T25G TURBO GOOD CONDITION $400
•HKS 850CC INJECTORS FOR 1JZ/2JZ WITH FUEL RAIL $900
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
