  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
this is what he got in
BANZAI MOTOR SPORTS
ITEMS IN STOCK:
•HKS GT2530 BB TURBO FOR RB20/25 GOOD CONDITION 320HP $1,650
•HKS GT2530 BB TURBO BRAND NEW 320HP $2,300
HKS T3G NON BB TURBO TO SUITE RB20/25 RATED SAME SIZE AS GT2530 $800
•HKS T300S (T4 STYLE FLANGE) GOOD FOR 450-500HP SUIT 2LITRES OR UP $1,300
•HKS T04R KIT FOR RB20/25 650HP KIT INCLUDES(HKS T04R TURBO, HKS CAST LOW MOUNT MANIFOLD, HKS EXTERNAL WASTEGATE, GREDDY TYPE R BOV AND SOME ADDITIONAL PIPING)
$2,600
•2X HKS GT2835R TURBO’S BY THEMSELVES EXTERNAL TYPE
$3,500 FOR PAIR OR $1,800 EACH
•HKS SQV NEW TYPE BOV KIT FOR RB20 GOOD CONDITION $310
•HKS USED T04R TURBO BY ITSELF 650HP RATING $2,000
•HKS NEAR NEW STEP II GTR CAMS 264IN 272OUT $800
•HKS USED MUCHROOM FILTER $90
•APEXI EL SERIES II BOOST GAUGE 60MM MECHANICAL NEW $220
•BLITZ SUPER SOUND BOV USED, KIT FOR S13 SR20 AND CA18 $220
•GREDDY TYPE R RACING BOV USED KIT FOR GTR GOOD CONDITION $350
•GREDDY V-SPL INTERCOOLER KIT NEW FOR S13 $1,550
•S14 STANDARD JAP SPEC BALL BEARING TURBO AWSOME ON CA18 OR S13 SR20 $800
•1JZ 2X STANDARD CT12 TURBO’S CHEAP!!!!! $400
•6X STANDARD R34 GTR INJECTORS, GOOD UPGRADE ON CA18 ETC $650
•NEW Z32 AIR FLOW METRE $450
•S13 STANDARD SR20 T25G TURBO GOOD CONDITION $400
•HKS 850CC INJECTORS FOR 1JZ/2JZ WITH FUEL RAIL $900
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
