  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
this is what he got in
BANZAI MOTOR SPORTS
ITEMS IN STOCK:
•HKS GT2530 BB TURBO FOR RB20/25 GOOD CONDITION 320HP $1,650
•HKS GT2530 BB TURBO BRAND NEW 320HP $2,300
HKS T3G NON BB TURBO TO SUITE RB20/25 RATED SAME SIZE AS GT2530 $800
•HKS T300S (T4 STYLE FLANGE) GOOD FOR 450-500HP SUIT 2LITRES OR UP $1,300
•HKS T04R KIT FOR RB20/25 650HP KIT INCLUDES(HKS T04R TURBO, HKS CAST LOW MOUNT MANIFOLD, HKS EXTERNAL WASTEGATE, GREDDY TYPE R BOV AND SOME ADDITIONAL PIPING)
$2,600
•2X HKS GT2835R TURBO’S BY THEMSELVES EXTERNAL TYPE
$3,500 FOR PAIR OR $1,800 EACH
•HKS SQV NEW TYPE BOV KIT FOR RB20 GOOD CONDITION $310
•HKS USED T04R TURBO BY ITSELF 650HP RATING $2,000
•HKS NEAR NEW STEP II GTR CAMS 264IN 272OUT $800
•HKS USED MUCHROOM FILTER $90
•APEXI EL SERIES II BOOST GAUGE 60MM MECHANICAL NEW $220
•BLITZ SUPER SOUND BOV USED, KIT FOR S13 SR20 AND CA18 $220
•GREDDY TYPE R RACING BOV USED KIT FOR GTR GOOD CONDITION $350
•GREDDY V-SPL INTERCOOLER KIT NEW FOR S13 $1,550
•S14 STANDARD JAP SPEC BALL BEARING TURBO AWSOME ON CA18 OR S13 SR20 $800
•1JZ 2X STANDARD CT12 TURBO’S CHEAP!!!!! $400
•6X STANDARD R34 GTR INJECTORS, GOOD UPGRADE ON CA18 ETC $650
•NEW Z32 AIR FLOW METRE $450
•S13 STANDARD SR20 T25G TURBO GOOD CONDITION $400
•HKS 850CC INJECTORS FOR 1JZ/2JZ WITH FUEL RAIL $900
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
