1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
^ obviously not written by me cos all that = a gay guy!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
where is looks..???
yeah i was thinking wheres the butt and eyes and smile - maybe im just shallow!! but serenity? sounds boring - geez i dont want to go out with a monk!! I think they just took out basically everything that makes a guy interesting!! sure they should have some of those qualities but i think a guy with all of them would bore me absolutely!!
Aidwin - *sigh* it has a badge and an extra turbo and an extra $10,000 to pay for one to me - thats the only thing that sets them apart - nice car, wish i had one but its like a Holden Clubsport and a Holden GTS - look the same - different badges, different power ratios, different price tags thats it!
All that dancing must keep you fit Liz!
Niz - yeah I am fit... but I don't look it unfortunatly. irish dancing makes my legs thick... it sucks hhahaha
Drifta - the other one I have not seen.... I will see it next week. He wants about 24K for it I think... 96 series II - no mods... sounds pretty good. But I love that one at c-red...
ralph mag website probably has some - hehe utter crap but funny.
Going down is:
Just the tip of the iceberg when it comes to things you can do in bed.
A phrase heard in lifts. :P
Best when reciprocated
Hope i didnt make anyone blush - just thought it was funny.
Guest
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
