  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
In the end the high flow rb25 and gt28 will have similar wheels etc, the high flow will just be able to sit on standard manfold and keep original/current dump pipe. Im sure the rb25 can push more then 300 rwhp i was being conservative, simon is pushing those type of numbers on his high flow rb20. the rb25 would have more
Guest
    • Noice. Congrats on the big day too!   don’t forget to never eat in the Skyline 🤣
    • Overnight parts from Amazon, let's go. Replaced nearly every o-rings, minus 2x from the pumps. Seems the kit is short? Then again when I replaced the main pump a few years back it did come with new seals so we are good. Yiewwww, ready for legal stimulants.
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
