its a thing you slide into your handbrake to not make it click into place. its just a hollow piece of aluminium with some major aftermarket ripoff brand like HSK, TDR, BLITS etc engraved on it and costs like $30.
Or you could just shove something like your mum's sewing thimble in there instead. I'm sure someone has a DIY on how to make one. its got to be the most simple yet "drift necessity" item in the drift merchant's repartoire.
Cut your handbrake cable... its even easier. :)
A "drift button" what on earth is that?
Ooo... maybe a but that you press and it makes the car drift the next corner you come upto...
automatically!
:ph34r:
it's a thing you put over your handbrake button so it's always pushed down, so all you need to do to get the handbrake going is a quick tug up.
also means you don't have to push the button while trying to get it down...
Yes lets all cut our handbrake cables that way when we go to drift we really wont be drifting we will look like idiots swerveing for no reason.:D
Not flaming just having a laugh.:D
You gotta cut the handbrake spring to fit a drift button anyway so cutting the handbrake cable is pretty close to the truth........
What we really need is a thread on how to reverse a drift button mod when you get defected by the cops.... :)
Thanks lordsnipe (for the link thingy) and everyone else for contributing. I never knew you could get defected for it. Thats something new to me. Well no surprise since most things are defectable. Thanks again all.
:lol:
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
