  • Replies 100
Theres a pic of that dr30 at the auction yards in Japan just before Ben bought it with 16 watanabes on it. Do you mind me asking around what you paid for it Disco?
Like less than 10g?
That car appeared in 2 or 3 issues I think.
:D Ya can't get much more affordable rubber than 235 45 17", commodore sizes and cheaper than the last pair of 215 50 16" I bought in the same tire.
Theres nothing wrong with a bit of stretch :D
Fantasy performance manifold B)
Edited by DR JOSH
More than 9 less than 10 , yes been in a few magszine articles out here . I'm not sure what you call a "Watanabee" but mine have Rays Engineering stickers in them and are model specific ie right on the money offset wise . They had 205 55 fronts and 225 50 rear tyres which is better than wider fronts with wrong wheel offset .
I defy anyone to get more rubber on the road without lots of caster and just a smidge of negative camber . Turn in is far better than any strut Nissan I've ever driven . With the 205's it easily has more grip than the back which is the next area to mod provided the Bluebird power rack conversion dosen't get in the way .
If anyone wants a clean DR with a bit of history it's up for grabs , I want what I paid for it .
Cheers A .
Attached is a pic of some Watanabe's :O
Must have been Ben that changed them cause the next issue containing pics of your car, the Volks were fitted.
He also had it dynoed with 127kw atw with just the cat-back e xhaust fitted.
AFR's were 14.4:1 at idle and around 11.8:1 at full load :P
edit: Sorry bout hijacking ur thread Josh
Edited by slide247
The Vulks are composite (two piece) and look to have forged centres . Four piston calipers would fall in , theres that much room around the std calipers . Yeah sorry Josh , mine is same colour but all over with no lairy stencils . Do all these RSX's have black and red interior ?
Cheers A .
Just though I'd chuck up some photos of my beast before paint work, then I can put some up after.
The motor is currently in being machined.  B)
Josh,
Can you make a template of the mount plates for your strut brace and post it to P O Box N89 Campbelltown North NSW 2560.
Tah,
Dennis
Josh,
Tah,
Dennis
Ghost rider, I have a adjustable frount strut brace (cusco I think) in my DR but is only 2 bolt per strut top. Don't know if this is what you are looking for.
Cheers
Thats Neame's DR Adam, before he had an altercation in it...
My interior is black with red inserts, i think the RSX had the stripey interior whilst the RS just had the plain black/red interior..Correct me if im wrong!!
:P Ya can't get much more affordable rubber than 235 45 17", commodore sizes and cheaper than the last pair of 215 50 16" I bought in the same tire.
Affordable maybe, but what do you do with the extra 10 odd Kph the speedo is under reading with these 235/45 x 17 on board.
And do you know, the optimum tyre size for any R30 is 245/45 x 16 as they have the correct dynamic radius (same as 205/60 x 15) and they have the widest tread etc, etc, etc.
Why do anything else if it's just for show?
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
