hey guys just got my rb20 tuned and finished today, its didnt pull the power i wanted but i think this is due to lack of boost, i have high flowed turbs and all the supporting mods to run over 320rwhp, but when they went to tune it at 18psi, it would spike there then drop straight back to 12psi, wat is the deal there, there is no leaks in the cooler pipin anywhere as they thoroughly went over them, could this be the actuator on the turbo giving in, or would it be the stock bov opening up? how to i test these 2 things, any recommendations on wat it is would be greatly appreciated. So atm its tuned on 12psi.
https://www.sau.com.au/forums/topic/88513-just-dynoed-rb20det/
thats the thing, they installed my apexi boost kit for the power fc, they said it wasnt working very well because it kept losing so much boost and couldnt hold it at 18psi at all, so i gave them my old manual boost controller, and they tuned it for 12psi and said that the manual one worked a bit better and wasnt so spiky, they still couldnt get it to stay at 18psi with the manual boost kit.
I found my stock actuator would drop back to 10-11psi at any boost above that.
An aftermarket adjustable would be well worth a look for 2 reasons: 1) you can set a higher base boost on the actuator and so are garanteed of that whatever your ebc does, and 2) The higher the base you set, the easier it will be for the ebc to do it's job and as a result you will have a more stable system with less spiking and a flat line to redline.
I also have a feeling the stock actuators aren't that good at holding anything above 10psi, unless combined with a decent EBC to pulse it.. Mine can sit on 13-14psi, but always dribbles back to 10-11psi in the higher rev range.
It may be one of those varying things - some factory ones may be fine, others get old and not so good.
I've got an RB20 and RB25 actuator sitting around, should do a couple of swaps and see which is better (onto rb25 turbo).
No.
Boost ramps up harder.
Try not to think about it too much. It works, that is why adjustable rods were created. :blink:
The RB25/VG30 actuator is quite soft and can be adjusted by hand, the RB20 on the other hand requires a big dirty screw driver to be levered against the elbow.
Edited by Cubes
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
