  • 4 years later...
  • Replies 50
mine is a mushroom shaped pod filter, its very very dirty and hasnt been cleaned at all, do you think if i cleaned it and sprayed it with sicoline (what they spray on bike filters) it will be fine??? or are the hks ones supposed to be dry.
cause readin this thread nobody knows for sure...
any hard info will be great guy
Bit of thread necroing here lol...
If its a foam filter, you can wash it in mild dishwashing liquid without too many dramas.
I would never run a foam filter dry, always apply oil. Buy some decent filter oil. From memory you can get a large can of Fuchs filter oil fairly cheap.
The reason they spray motorbike filters with silicone is only for water resistance, as these filters are run open to all weather conditions. In a car's engine bay it would see minimal water contact.. so its probably not worth bothering coating it.
Edited by _x_FiReStOrM_x_
  • 1 year later...
no mate its not. its completely normal. however look into replacing your filter. the mushroom ones are the worst of the lot
Hey mate, thnx for letting me know, and plus i had to ask this, while testing my car at 160kph, i found a whistling sound, im not sure wat is it related to , didn sound very convincing though, btw any specific pod filter brand suggessions??
thnx heaps
According to Pod Filter Reports in Mags and Toyota forums,
If you have AFMs it's better to use a dry filter rather than wet (ie oil). Apexi pods came out best along with one other.
If you don't have AFMs (as in the case of using an ECU like HKS F-Con Pro-V), you can use wet or dry filters.
HKS Pods rated very poorly for both filtering action and flow rate. K&N is a good wet filter system.
If you already have HKS induction with HKS pods, and you have AFMs, I'd switch to the dry Simota pod sponges (or Apexi) instead.
And they're available from Just Jap. I believe for extra protection, there is a very fine mist aerosol that can still be used with these.
If there are newer reports contrary to what I've stated, I stand corrected.
Cheers, T
  • 6 months later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
