  • Replies 93
Well we are tuning it this week, expcet about 500hp at the wheels, this is without cams or agressive tuning, we want a reliable package.
The 4liter in the RZ is ok as it is a 25% increase in capacity which is allowed, I don't think you can do it in your case unless you have engineering certificates.
As we already had the engine and turbo the total cost is mainly in man-hours. We haven't come up with a proposed cost yet as we still have to tune the car and finish minor issues.
See'ya:burnout:
Guest Miles B
VSPEC.. I'm considering turboing a 1UZFE Soarer. Can you give me some details? Keen to know how much it cost, what you used for fuel management, details on the fuel system, manifolds, and how you decompressed the engine. Just a few quick details on each would be great, you don't have to write an essay.
How many psi are you running?
Miles B,
We will be initially tuning the car with a very conservative setup of about 10psi, to see how it repsonds to tuning. We have a single T78 sitting infront of the engine, there is plenty of room as the 1UZ is smaller in length. Engine management is via an Autronic SM2, manifolds are custom made.
I will attempt to get some photo's and post them for you, and will give you an estimate of the cost.
See'ya:burnout:
Miles,
We have left the pistons stock for the moment and just used head gaskets to decompress, although in the drag car we built using the 1UZ we have used pished pistons aswell.
The Motec will be good, don't think too much about the Autronic, too much mesing about.
See'ya:burnout:
Guest BigRod33
GTS-t VSPEC,
would love to see the engine bay pics of the supra if you have some.
this project that ricknismo is talking about has not had an upper budget limit on it. any help you can supply would be appreciated, even though we acknowledge that traffic rules between the two states are going to be different, any tips on what stage a mechanical engineer should be brought in. i.e should they be part of the build up from go to whoa to ensure that money isn't wasted in the wrong area's.
has anyone else done this in qld and had it approved by main roads dept.
BigRod33,
With our car the 3->4litres is allowed under the current legislation, therefore the engineer only needs to confirm that the power output on the car is supported by the braking system. We are expecting very few problems getting it over the pits, be we shall see.
I'll take some photo's soon and post them.
See'ya:burnout:
Guest Works Auto
If ya gonna put a v8 into a r33 , use a nissan v8.
I know where there is a nissan cema vh41 if your interested.
I think he wants 2g for the half cut. PM if u want info.
I heard the motor running in the cut its quite impressive.
4 cams 48 valves etc etc and revvs to 7500 no worries. Which means would be perfect with a turbo.
Not bad for an 8.
Why do you want a twin setup, a big single will definately do the job. You'd be surprised that the V8's are quite a bit shorter in length, and it provides quite a bit more room to fit things in.
I know that the Infinity has been done before, I wold stear clear of the Lexus V8 in a Skyline due to licensing issues.
See'ya:burnout:
Guest BigRod33
hitnrun, thanks for the tip with performance forums
GTS-t Vspec, once you have photos etc can you email me.
also, any opinions about which would be the better motor VH45 or VH41.
also any ideas about availability of aftermarket internals for either of these motors???
thanks for the juice so far
rod
BigRod,
The car is at the tuners at the moment, so the pics may be another few days coming, but I'll post them for everyone.
I know that for the 1UZ there are lots of aftermarket parts, including a 5litre strocker kit, hell yeah.
For the Nissan engines there are some aftermarket stuff, but you would be better off having it custom made in Oz. For huge horsepower then the 1UZ is hard to pass on, with bullet proof internals, 6 bolt mains etc, and a host of aftermarket gear.
See'ya:burnout:
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
