Hey all,
well been reading here since before i got the car, and i had a website for my last car which showed the progression over the years and now im starting to do one for the skyline. only had it six months, so not much there, but who knows maybe someone might enjoy looking at it.
so here it is..
http://members.optusnet.com.au/damage/
well any comments or opinions feel free to post! :rolleyes:
thanks!
shaun.
https://www.sau.com.au/forums/topic/88652-website-on-my-skyline/
its a panasonic unit, wasnt hooked up and has no wiring diagram on it to determine anything about it, just a model number. cant find anything on it.
looks like a central unti for everything. has buttons for sat nav stuff, cd stacker, tv controls, theres about a dozon buttons on each side of the screen for various stuff.
thanks for the comments :P
shaun.
a forum i used to be on made threads for it...and you show pics of your car when you got it, and then the progress you've made, step by step...with a bit of info about each stage etc....it was a good idea....people enjoyed seeing the progression of members cars all in a thread for each person
WOW dude, you joined in early august and now you have 1,054 posts....that means in less than 2 months you have 1000 plus posts...goodness..hahaha...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
