In your first post you said "suspect there is a major airflow restriction"
Have you considered the size of the air filter being a restriction at high rpm?
Have you tried taking off the air filter and seeing if this helps?
Saying this b/c a friend of mine in his rb30det changed to a newer (smaller) air filter compared to the original one he had on and with only this change lost approx 35rwkw.
Yeah, tried removing the airfilter, gained only 3rwkw.
Archie- How much power is your mates RB30det making, and what size differences were there between the 2 air filters he tried?
Edited by sky30
valve float is a possibility too, didn't think of that. the exhaust manifold is reaching its limits pretty hard up around those sorts of airflows though, it seems to be the likely culprit if you've tried adjusting the cam timing with no significant effect.
Upgrading valve springs alone will not resolve valve float if there isn't enough seat pressure to begin with. It will only resolve the issue if the valve springs are too soft to handle the inlet and exhaust pressures when making some decent power.
I.e comparing my head to Bl4ck32's. Mine was nice and tight, bl4ck32's was loose and required shimming, upgrading springs in bl4ck32's head would have made a small difference but not completely resolved the float he would have experienced.
Yours may be fine, but it is something to look in to. Much cheaper than replacing the exhaust manifold.
Bl4ck32 is currently running 16psi on stock n/a springs with zero signs of valve float.
Its something you can do yourself.
Edited by Cubes
G'day Sky - I'm the guy who changed pod filters and saw the power drop...
I went from 350ish rwkw to 312 (or there abouts)....
My skyline made good power from about 3500rpm right through till about 7000rpm, and power dropped off gradually after that (7500rpm limit).
I went from the old style apexi pod filter (the round/cylindrical model) to the current cone-style model - and saw this power restriction.
To be honest, if you've already checked that, I'd (As previously mentioned) get a couple of gauges and measure the pressure drop through the intercooler... My car had a 4" IC core, so it's very possible that your I/C is your restriction...
Your intake plenum is fine - I retained the factory plenum and never had any real flow restrictions.
Cheers,
matt
Joel-
Upgrading the valvesprings does give more seat pressure, it totally fixed my valve float problems. If Darren is only running 16psi, it may not be enough pressure to cause float, mine only occured when running over 18-19psi.
Sky30, I think you don't understand what I mean.
If your valve seats are pulled up in the head the stiffer valve springs will make some difference but not completely resolve it.
Lifter jacking to the point where it causes the car to miss is the extreme end of valve float, that is being extremely close to smashing valves on the pistons.
It may not be the case but its something I would look in to especially after bl4ck32s head being so loose from factory. Its easy to check. :O
I still think its the stock exh. manifold and nothing to do with the above, but its worth a shot. :P
Here's a little tech write up on seat pressure.
http://www.cranecams.com/?show=faq&id=5
Edited by Cubes
Joel- I understand you mean some heads have their valve seats recessed further into the head, But by using a longer spring it will do the same job( if not better) than using shims under the stock springs.
Its only a suggestion, if you are 100% confident the valve springs have good seat pressure and are not floating under high back pressures then I wouldn't worry about it. :O
The inlet mani is fine, the exhaust is fine and the valve springs are fine.
That leaves the fmic and exhaust manifold.
I would probably look at trouble shooting in the following order
Drill/tap pressure guage in to exh mani or turbo housing.
Then consider if the exh. manifold needs replacing if there are extreme back pressures that may also be causeing a little float and reversion.
Replace FMIC
As I said quite some time ago.
The bloke I bought that machined GT35R turbine housing off had it on his stock exh. manifold, he was running 18-19psi with 256duration cams and made 306rwkw. That was the limit.
He changed exh. manifolds to a ext. gate setup and on the same boost picked up 20rwkw.
How much of the 20rwkw was due to the exhaust manifold is to be debated. :P
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
