hey guys, this afternoon i changed my oil, oil filter and fuel filter, fixed up some bad earth wires from battery to the body and tried to install turbo timer, when i went to start my car it fired up find and the turbo timer worked as well, after rechecking the oil level i went to drive the car and as soon as i hit boost the car broke down really bad, i putted home and let it idle and it was fine but as soon as i revved it it starts missfiring really really bad and backfires extreamly loud sounds like gun shots, i think a bit of oil got on the first coil pack so i took it off and wiped it off as much i could and cleaned where the plug sits, i left the car for a while and unplugged the turbo timer completly and went for a drive it started missing again but only on boost so i kept off boost and tried to go back home then all of a sudden it misses all the time now i can even take off with out it breaking down and backfiring really loud, i think it mite be a leaking injector or a few but not sure how to find out, its undrivable cause as soon as i touch the accelerator is breaks down and pops, my fuel gauge has gone down 1/4 tank and i only done about 5km but had it sitting there idling a for 20 min or so. is there any way to confirm leaking injectors or what? i dont wanna have to take em out and find they are fine, any one else had the same problems? sorry for the long post and help would be great thanks.
https://www.sau.com.au/forums/topic/88897-leaking-injectors/
did you unplug the AFM?
i would check that connection and maybe give that a clean first
it seems odd that you would only do a service and then all of a sudden you would find that "a few" injectors were leaking? not likely...
maybe also check that you have earthed the battery properly and that there isn't a loose connection somethere at the negative terminal
Warren.
My guess, the ECU has gone into limp home mode. You shorted out something when you were playing around with the wiring or you have left a connector unpluged. Check the error codes, that will tell you what WAS wrong. Then reset the ECU and take it for a drive, check for error codes, that will tell you what is wrong NOW. Then fix what it is that the error codes are telling you is wrong.
If you don't know how to rear the error codes or reset the ECU then do a search. Plenty of info on the forum.
PS. turbo timers are a waste of oxygen, just make it easier for someone to steal your car. What dod you have a turbo timer for? Cooling dowwn the turbo? What about a gearbox timer? Or a brake timer? They will be just as hot as your turbo. Cool it all down, do a slow lap of the block before you park it.
:D cheers :D
why does every1 diss turbo timers?
i know when im runnin late for work i dont wanna sit in my car or go really slow 2 work just casue "you dont need them"
i use mine alot
because if you crash your car and are unconscious in the drivers seat the timer will keep petrol flowing to the engine bay....nice way to fuel a fire id say :D
ok guys, thanks for the help, the car fixed it self i think, i worked some more on it, changed plugs back over to old ones and it didnt start at all then changed back and it still didnt start.. i started swearing at it uncontrollably then my dad came out and started it and it worked fine! i HATE cars.. argh. yea turbo timer is more wank factor. cheers
i use mine alot
Driving flat stick doesn't really get you to work that much quicker. :D
Light to moderate on boost you don't need to leave the car running, just be sure turning the car off is the last thing you do before getting out the car, this gives the turbo time to spin down.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
