SAU CRUISE - Saturday February 1st.
  • Replies 121
Originally posted by Stoffle
That sounds kind of spooky :P j/k
Stoffle someone was telling me about someone getting their skyline on tuesday and then they gave me a link to your site, seems everyones speakin bout ya, all good tho :D
im still new to the world of skylines too :uh-huh:
Originally posted by 002 NVS
Is their a look out at Mt. Gravatt or something.?
I have heard of peopel going there but I don't knwo where it is..
Would anyone like to give me some directions so i can have a look?
Scott
You go along the South East Freeway (South of course) get off at the Marshal Road Exit... go Left at the bottom onto Marshal Road. Go down the hill then up again then down a little bit and you will come to a major intersection. This intersection is Logan Road and Marshal/Holland Road. Go Right at these lights and head along Logan Road. You will go through 2 sets of lights (past all the car yards) and come to a third set of lights closely followed by a fourth set. Turn Right at the third set and go up beside Red Rooster. Follow this road all the way to the top and there you have Mt Gravatt... Don't go too stupid up this hill for the first time... About 3/4 of the corners are sharp and blind... Many accidents on this hill.
Guest Boxhead
have it at a chinese resturant, coz funny stuff always happens when you have a bottle of soy sauce, someone with the intelligence of a 12 yr old, and $21 for he who drinks a cup of the soy lol...
a bit side trackin, talking about weight.. does anyone know how i can loose some weight? ive tryed the eat healthy crap, but it tastes like crap too.. hrrmm and excersize is boring on your own...
well its your money not mine so its your choice and in reply too you losing weight try maybe eatin less food?? or i read somewhere if you bang your head hard enough against a wall you lose something like 12 calories. and plus whats wrong with icecream cake and maccas?? last time i saw there were 10 skylines park outside maccas. and they werent meeting in the parking lot either
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
