i know its been covered before because ive read it but i cant find the bloody thing,
ive got a power fc which was bought with a motor, it was all good in the other car, but as soon as we put the motor in my car, tuned it when we turned the car off and back on it wasnt memorizing the new settings, just went back to a base map..
like i said i know its been covered before but what could be some solutions, is it somethin to do with my loom? pwoer cable?
any info would be great
ben...
https://www.sau.com.au/forums/topic/88993-power-fc-not-memorizing-map/
nah its not locked, but yes my mechanic tunes alot of power fc's which is why it has him stumped, does the ecu need more power when the car is off or something?
ben...
I think INASNT on here had the exact same problem. It was to do with faulty wiring. Not sure if it was faulty wiring going to the FC or the wiring in the car its self. PM him
It's not an old Power FC is it? I remember reading on these forums that older Power FC's use a small battery to store the settings in it's memory, kind of like a computer's motherboard stores it's BIOS settings. Could this be the case?
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
i remember reading a post on this forum about the same problem and the solution was the the alarm or something to do with it.
Apparently the pfc needs power for a few seconds after the car is switched off to save its settings.
Thats all i can remember reading about that problem.
You need to make sure the eccs relays are wired in correctly as well as the ignition switch signal to the ecu.
The ecu triggers the eccs relay to power up everything when it receives the ignition switch on signal. It also maintains power to the ecu for a second or so after the ignition is switched off which is when the pfc writes everything to memory.
BHdave is correct, we spent some time fixing my car a while back
The ECCS relay is powered by the ECU, and must be turned off about 2-3 seconds after the igition to allow the FC to store the tune.
The Ignition switch powers up the ECU, The ECU now powers up the ECCS relay which in turn powers up the ECU completely and the coils, ignitor, injectors etc etc.
The problem seems to lie either with the wiring from the ECU to the ECCS or with the ECU itself.
Now Instead of tracing a potentially massive wiring issue it is simpler to make a switch circuit and wire it into the loom.
Using a capacitor, relay and diode you can make a circuit that will hold power to the ECU for about 4 seconds.
Basicly you need to wire up the condenser so that when you remove ignition it is powering up the relay which is spliced into the main ECCS feed to the ECU.
I have used this method on several vehicles with a 100% sucess rate.
I had this same thing happen to my first FC
thanks to good old mohammad from these very forums, at very short notice of finding out the current FC was doing this, I rang him as he had told me he had heaps of parts.... anyhow 30mins later he rocks up to the workshop with a FC for the GTR!!! amazing! faster than a pizza!
plugged in the new FC and bingo all ok....
basically I was told by BEL that these problems are a known fault with the FC and that Apexi know about it...
I then rang the guy i bought it from originally... and he had to send it away to get looked at and repaired...(SAU trader also...but not as user friendly as Mo :) )
well that was 4 months ago!!!!
and no sign of my FC!
once I get it back and it is factory repaired I will test it and then sell it....
so yes it is a fault that apexi know about....
ring BEL for some contact info for apexi....
williamsf1 - is yours the newer version ? if apexi know about it perhaps they would replace under warranty ( useless if its a design fault ) but then again power fc's been around for god knows . unfortunately i have the old one ( no warrantys there )
symtoms of my one are- (second hand unit 10-15 yo? )
when you turn the key to acc the relays in the kick panel behind ecu would tick like crazy (sumtimes)
relays in the boot would tick like crazy (sumtimes)
replace power fc with standard ecu and problem solved
end result i hav purchased power fc d-jetro
Risking: good info thanks for than
just a note, a while ago i bought a power fc which made it do the same thing, and apparently that was the older one so i bought another new one which fixed it,
only thing that had me thinkin it wasnt the ecu itself is the fact that it worked in another car so it must be my car's wiring thats all over the shop
ben...
well my current FC kills instantly...
I have it on good authority that this is a comman fault that is described above.... just contact apexi here in OZ or if you cant call BEL garage as they know of the problem...
Im still waiting to get my first unit back!!!
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
