  • Replies 105
I will be packing this arvo, jus need to get some last minut things (power adaptor, etc) and im ready to takeoff for tokyo tomorrow night!!!
I will see you and nick for autosalong on saturday :unsure:
Edited by Blitz_R33
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
