  • Replies 105
DR_DRIFT
Did you get my email as i have had no reply.
I am after the ash-tray, how does $10 sound. If not name a reasonable price.
I am from melbourne and can pick it up asap.
Al - Sorry.... demand is a bit higher than $10.... seems a few people want the ashtray?? E-mail me and we can negotiate....
RS72 - Centre Cup / Coin Holder available... currently under offer but no $$ exchanged hands yet... e-mail me to work something out??
Sidewaymambo - Not sure exactly what you mean?? 0411 878 961 if you'd like to clarify...
After steering column shroud - thingo, the two bits (top & bottom) that go between the steering wheel and the dash - My old one had guages on it, and now there are holes in it.
Actually, I just need the top bit...
Cheers,
Boost Junky - I have standard front springs, rear is sold.
Matt31 - SOLD
Brendanf - Collum shroud is perfect, e-mail me an offer.
I will do a complete list of everything in my shed or on the car shortly.
Hey DD i need some parts if you have them.......
Indicator stalk
fuse box cover (the one from the engine bay)
Driveers side rear indicator (the clear lense on the outside under the two red taillights)
Pls let me know either way
thanks.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
