Greensborough/Mill Park/Heidelburgers
  • Replies 115
I saw you and your gf driving around your respective R33's the other day, near the BP on Dalton rd in reservoir. I honked but you didn't look. I was in the maxima which probably didn't help.
I know its not near the cop shop but was it parked where the milk bar is ? next to bobos pizza ?
noone here is from epping ?
Saw a white 34 there once with an asian dude looking worried & checking out his tyres or something?? Was going to offer some help but he disappeared before I had a chance to :)
yeah seen it.
sorry i didnt come on sunday i woke up real late and was too tired.
next meet definately
Hey Guyz, im a local from Epping, was hoping to get in touch with sum locals, always see guyz drivin skylines, give them a beep and a wave, sumtimes the odd wave back... im just of maccas rd? any1 else near there???
Joe (White R32)
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
