This doesnt look right it just dropped in the AF section can you please let me know what the problem is?
Nothing unusual, standard Skyline ECU Rich and Retard strategy. The R34 ECU is very agressive in implementing R&R. Time for some tuning.
:O cheers :)
:O cheers :)
Oh okay cool was worried for a sec.. but why did it just drop all the way down an flat line.. should also add the ecu has been tuned by Mines and that worries me also..
damn 10....AFR's...do you get bad km's per tank full?
Around 300-350 how would i go about to correcting this would i need to find a stock ecu for my car? or just go and buy a SAVC
Not to be offensive but dont be cheap when it come to an ecu either....
I mean you paid 30+k for your r34 im sure... Spend a grand and buy a pfc... You will love it...
Yeah i was thinking of getting that instead but i thought the SAFC would do the same job. anyways guess myfront mount will have to wait
I got FMIC before ECU and found the car ran bit more boost.
THis is on a 34 GTT though, same car as the one in question :cheers:
SAFC won't do timing but yes it will correct your AFR's
If you car is auto then you will find it hard to get your hands on a stock ECU.
Manual there are a few on the forsale section.
Hey I have an auto R34 too with the SAFCII installed and tuned... AFRs are now floating around the 12.2-12.5 mark but I'm still only getting about 350kms per tank
Any reason? Any fixes? Cheers guys...
Well right now i am blaming the problem on the Mines Chip on the computer cos i cant blame anything else but when i replace it i will post the difference
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
