  • Replies 40
Posted Images
  • 3 weeks later...
ah ok, yeah definitly landed
just had the compliance plate applied for like tuesday this week, should by complied by late next week, then having some work done on the car, so shouldn;t be too much longer till i get her!!
They sent off the letter for compliance plate before it was actually complied?
nice rims btw, not sure if I want white or black ones on mine :)
Cars not complied until the plate is stuck on her!!! I guess what i meant is that the workshop had approved to have the paperwork submitted and have the plate applied for!
Dezz im in Adelaide but the 34 is being imported through a WA based group, so all of the compliance work is going to be completed over there, then sent over here VIA train to be registered in SA. Compliance has taken quite some time for mine as it had a reasonable amount of modifications, and there has been some difficulty in securing stock parts to allow the car to pass compliance. Its been a long wait for me, but hopefully the wait will be over soon! I'm sure it'll all be worth it once i've got the 34!!!!!!
I'm not a big fan of TE37's myself, so im contemplating selling the rims, only if i can find another pair im interested in though.
They will comply the car before the letter for the compliance plate is sent.
Dezz: Currently there has been some hiccups in the customs department if you have read the news. It's about some new system that screwed up. Things being imported into the country will be processed slower than usual and that includes cars.
Journey from japan is going to take about 2 weeks or more, so you can count down from that.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
