Hi, Just got my car back today from RacePace. Ben & myself are very pleased with it.
I had someone sell me the wrong Spring for my wastegate - wanted 14.5 or 15psi spring but got a 25 or more?
Anyway Ben had a 10psi spring and the car made 284.6RWKW @20psi. I will be putting another spring in & try for 300RWKW.
The car feels great & Ben was right - It does feel like a lot more than 285.
Cheers
Chris
Edited by R33RWKW
  • Replies 48
Thanks guys
Mods are:
Full Rebuild RB25DET (Mahl forged pistons/GTR Rods/ACL Bearings/Headwork/std cams
Etc... (8:5:1) compression ratio
New Garrett GT30R 56T (500hp) (6 Blade wheel) (ex housing 0.82/front cover 0.6)
New HKS Cast Manifold (low mount)
HKS COPY 50mm Wastegate with 10psi spring (I might be replacing the whole wastegate if it gives me any trouble later with a Original HKS gate)
SCREAMER PIPE
APEXI Gt Spec FMIC
APEXI Power FC
Blitz Dual SBC (older model)
Blitz Turbo Timer
Viper Alarm (can't remember which model)
New Nismo 550cc Injectors
New SplitFire Coils
New Z32 AFM
K&N Induction ((Large oval Pod)
Jasma 3.5" Exhaust (4"tip)
New OS Giken Twin Plate Clutch & Flywheel
New HKS SSQ BOV
Greddy Timing Belt
NGK Plugs
Autometer Gauges 3 in console above cd player/ 2 in pillar mount -soon
Autometer Monster tacho with Shift light
Cusco Oil Catch Can
Nismo Front Strut Bar with slave cylinder Stopper
Teins
Bridgestone Potenza's SO3 - 265/40/ ZR18 rear/235/35ZR18 front
Upgraded Brakes (can't rember brand at the moment)
Lenso Alloys 18"
SETRAB 19 row oil cooler & Perma-Cool Relocation Kit (TO Be Installed by me & Friends)
Next to arrive in the post to complete my car are:
R33 GTR Rear wing & bootlid (includes Carbon Fibre GTR Side-plates on wing)
Nismo 300km dash (the whole thing - a direct fit/plug&play for the GTS-T
Complete Whiteline/Biliestin Suspension package (through SydneyKid's Group Buy)
When that is all fitted the last thing is a full respray, except for engine bay - POLAR White with a Pearl through it.
Cheers
Chris
Edited by R33RWKW
What size turbine housing?
Very nice complete setup. :)
Hi Cubes, I think it is 0.62 for the housing. I will check tomorrow. Sorry I have to go out again!
Cheers
Chris
Was yours the white the GTST? Was there at the same time as mine 'cept I was without mine for 10 weeks!
Nice result too BTW. :mellow:
Yep, Mine was the Polar White GTS-T with a couple of Scratches which are being fixed very soon.
you running a 3.5" dump also?
thats gonna make the difference that i didnt have :D
Also you got the slightly smaller one... hence the extra psi to get to 280
I'd take a staby-stab at it being a .82
If its a .63 then thats amazing results
Another quality job. Good to see that the stock cam'd RB25 heads pumping great power without the need to spend $$$ on em :D
Thanks Ash, I think you are right, more likely the .82. I must have been looking at the cover size. I'm not sure if it's a 3.5dump, can't remember. I will be talking to Ben tomorrow because he want's some feedback and I'm going to change the wastegate spring, maybe the whole waste gate.
What are your thoughts - Should I stick with a 50mm gate? or put a Original HKS 40mm one on?
Cheers,
Chris
Cheers
Chris
Should be 0.82 turbine housing, not 0.62
if your current gate is giving no issues and its not creeping too much, stick with it.
The idea wuith the rates is to get as close as you can to ur target psi off the gate spring where u can... im sure you already know that :D
mine crept heaps (45mm t/smart progate) in 4th/5th under load @ higher speed when i was using 7psi spring/17psi (bleeder)
using a 14psi spring/17psi (via bleeder) it was excellent and stayed shut in 5th much longer
on 24psi with the juice it was just mental so i didnt have time to worry about it.
find out about the dump, be interesting :D
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
