Hi,
Does anyone know how much gas and lubricant the A/C system takes in an R32 GTR?
I need to regass mine as there was no gas to start off with and it will be using the old gas (not R134-a).
The guy needs to know how much of the gas and lube to put in.
Got a figure of 500ml searching past forums.
Cheers.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/
pretty sure i saw a sticker on one saying around 650g of gas.. normal oil charge is written on the label on the compressor, not the easiest thing to read while still fitted in the car. probably around 100- 120ml of oil at a guess.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1622349
Good thread, I recently had my a/c regassed as the condensor was removed.
Initially the thing would lock up and almost stall the car. :P
Brought it back, lots of water in it, they regassed it now it works on and off and is no where near as icy cold it used to be.
Unsure exactly what they have done or haven't done. :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1624286
Best of luck with the re-gas and hopefully no problems arise.
They have just bought in a heap of new qualifications for the A/C people to try and adhere too. All gas has got to be accounted for - tight regulations and you will get screwed pretty bad if you dont comply.
Cheers
Sumo
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1625579
I had my air-con regassed at the local mech as they were doing regassing cheap. The air-con would only work for 1-2 mins properly before blowing more hot air. I took it into the local Nissan dealer and they discovered that it had been over-gassed causing the system to everheat. i paid them $90 and they regassed the thing properly. it's as cold as ice now...........well almost :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626015
i just got mine regassed a week ago, guy showed me there was barely any gas in there, regassed it now works fine, only thing is the clutch makes a clunk noise when u turn the a/c on for the first time in a few days, the guy said it was fine they sometimes do that, does anyone else have this happen?
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626168
That sounds super illegal... and really bad for the hole in the ozone layer
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1627343
stuff that was running r12 can be regassed with r12 if the leak is fixed, and the only problem with regassing with r12 is trying to find it, plus the cost. Its cheaper to convert it.
Its manly for the ppl in the industry that have bottles left over. Can sell it for over $60 a kilo
Edited by race_snooze
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1629591
Gees i bet the government wants to know who is still selling R12 a/c refrigerant. as it was phased out in 1996, and is pretty much illeagal to use/sell in this and just about every country in the world.
there was a gas made up when they phased R12 out, but it was only used for a few years as a substitute untill R134a was standard.
R12 is an ozone depleting gas. So if you want this planet to be around for your future generations i would suggest doing the right thing and convert the system to R134a
+ i would report whoever told you they could get you R12 becuase they are dodgy and i wouldn't trust them with my car anyway!
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1632690
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
