Hi,
Does anyone know how much gas and lubricant the A/C system takes in an R32 GTR?
I need to regass mine as there was no gas to start off with and it will be using the old gas (not R134-a).
The guy needs to know how much of the gas and lube to put in.
Got a figure of 500ml searching past forums.
Cheers.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/
pretty sure i saw a sticker on one saying around 650g of gas.. normal oil charge is written on the label on the compressor, not the easiest thing to read while still fitted in the car. probably around 100- 120ml of oil at a guess.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1622349
Good thread, I recently had my a/c regassed as the condensor was removed.
Initially the thing would lock up and almost stall the car. :P
Brought it back, lots of water in it, they regassed it now it works on and off and is no where near as icy cold it used to be.
Unsure exactly what they have done or haven't done. :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1624286
Best of luck with the re-gas and hopefully no problems arise.
They have just bought in a heap of new qualifications for the A/C people to try and adhere too. All gas has got to be accounted for - tight regulations and you will get screwed pretty bad if you dont comply.
Cheers
Sumo
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1625579
I had my air-con regassed at the local mech as they were doing regassing cheap. The air-con would only work for 1-2 mins properly before blowing more hot air. I took it into the local Nissan dealer and they discovered that it had been over-gassed causing the system to everheat. i paid them $90 and they regassed the thing properly. it's as cold as ice now...........well almost :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626015
i just got mine regassed a week ago, guy showed me there was barely any gas in there, regassed it now works fine, only thing is the clutch makes a clunk noise when u turn the a/c on for the first time in a few days, the guy said it was fine they sometimes do that, does anyone else have this happen?
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626168
That sounds super illegal... and really bad for the hole in the ozone layer
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1627343
stuff that was running r12 can be regassed with r12 if the leak is fixed, and the only problem with regassing with r12 is trying to find it, plus the cost. Its cheaper to convert it.
Its manly for the ppl in the industry that have bottles left over. Can sell it for over $60 a kilo
Edited by race_snooze
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1629591
Gees i bet the government wants to know who is still selling R12 a/c refrigerant. as it was phased out in 1996, and is pretty much illeagal to use/sell in this and just about every country in the world.
there was a gas made up when they phased R12 out, but it was only used for a few years as a substitute untill R134a was standard.
R12 is an ozone depleting gas. So if you want this planet to be around for your future generations i would suggest doing the right thing and convert the system to R134a
+ i would report whoever told you they could get you R12 becuase they are dodgy and i wouldn't trust them with my car anyway!
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1632690
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
