Hi,
Does anyone know how much gas and lubricant the A/C system takes in an R32 GTR?
I need to regass mine as there was no gas to start off with and it will be using the old gas (not R134-a).
The guy needs to know how much of the gas and lube to put in.
Got a figure of 500ml searching past forums.
Cheers.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/
pretty sure i saw a sticker on one saying around 650g of gas.. normal oil charge is written on the label on the compressor, not the easiest thing to read while still fitted in the car. probably around 100- 120ml of oil at a guess.
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1622349
Good thread, I recently had my a/c regassed as the condensor was removed.
Initially the thing would lock up and almost stall the car. :P
Brought it back, lots of water in it, they regassed it now it works on and off and is no where near as icy cold it used to be.
Unsure exactly what they have done or haven't done. :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1624286
Best of luck with the re-gas and hopefully no problems arise.
They have just bought in a heap of new qualifications for the A/C people to try and adhere too. All gas has got to be accounted for - tight regulations and you will get screwed pretty bad if you dont comply.
Cheers
Sumo
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1625579
I had my air-con regassed at the local mech as they were doing regassing cheap. The air-con would only work for 1-2 mins properly before blowing more hot air. I took it into the local Nissan dealer and they discovered that it had been over-gassed causing the system to everheat. i paid them $90 and they regassed the thing properly. it's as cold as ice now...........well almost :P
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626015
i just got mine regassed a week ago, guy showed me there was barely any gas in there, regassed it now works fine, only thing is the clutch makes a clunk noise when u turn the a/c on for the first time in a few days, the guy said it was fine they sometimes do that, does anyone else have this happen?
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1626168
That sounds super illegal... and really bad for the hole in the ozone layer
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1627343
stuff that was running r12 can be regassed with r12 if the leak is fixed, and the only problem with regassing with r12 is trying to find it, plus the cost. Its cheaper to convert it.
Its manly for the ppl in the industry that have bottles left over. Can sell it for over $60 a kilo
Edited by race_snooze
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1629591
Gees i bet the government wants to know who is still selling R12 a/c refrigerant. as it was phased out in 1996, and is pretty much illeagal to use/sell in this and just about every country in the world.
there was a gas made up when they phased R12 out, but it was only used for a few years as a substitute untill R134a was standard.
R12 is an ozone depleting gas. So if you want this planet to be around for your future generations i would suggest doing the right thing and convert the system to R134a
+ i would report whoever told you they could get you R12 becuase they are dodgy and i wouldn't trust them with my car anyway!
https://www.sau.com.au/forums/topic/89745-regassing-aircon/#findComment-1632690
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
