  • Replies 625
Posted Images
There is nothing wrong with being a cruise whore...  so who's going to meet me at Chatswood :D
Hey Stan,
Might join you on this one! Would be my first SAU cruise!
I have a 21st the night before so pending a hang over might join you all!
:D
Cheers Robbie... and as Brad Pitt would say; "IS THERE NO ONE ELSE.... IS THERE NO ON ELSE????"
Maybe if I wear a leather skirt and a tin helmet whilst waving my magic stick around, this would have more effect :D
Links - Dick Smith Unidens (twin pack was $60)
Blitz - Cool, 9am behind the train station where the taxi rank is, that way we can just go straight up the Pacific Highway.
RAILWAY STREET to be exact :)
* Was going to put a map in from WhereIs.com but it ended up being really confusing :lol:
Edited by satanic
Yeah that would be better me thinks :) (this is why I don't organize big cruises, only little ones) :lol:
So as Blitz said it will be at a servo, can you please put up which one? Maybe a map for those coming from across the bridge?
What about at the BP before Chatswood.. they have parking there.. it's just after the epping road/lane cove road turnoff heading up the pacific hwy..
Where are most of you located that want to meet early.. i'm in north sydney.. stan is in manly..
There is nothing wrong with being a cruise whore...  so who's going to meet me at Chatswood :)
Ill prob be driving past there on my way up to thornleigh at about 915 so might just do a drive by and link up..........unless I go up the M2. What time are you gonna be there till??
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
