  • Replies 625
Posted Images
Me ?
Organise something?
You gotta be kiddin me. I wouldnt know where to start!
Liz .... u know you want to organise it !!! :(
Meet at thornleigh maccas
Cruise to hornsby heights
go through galston gorge
cruise via old northern road to wisemans
have a feed and some photos
go on the ferry.
go up to gosford along that road (turn right from the ferry) (its actually quite nice. long and windy. Great fun. Pretty empty. and probably no cops
And then turn off to go back to sydney ??
:D
Eh ?
Me ?
Organise something?
Liz .... u know you want to organise it !!! :)
go on the ferry.
:D
Eh ?
We already did a Wisemans cruise this year that Moonie organised, I ll go again but :(
SL 32 IM - Sam..
most ppl know me by now..
and marss ya f00l.. Why didnt you come up and introduce yourself before we left.. then I wouldnt have ignored you later haha. .nah.. I didnt see you waving lol
ps. next cruise, I will actually cruise on i hope :P
And MAR55S, I didn't mean to give you the finger... thought you were Links :D  My bad... don't take offence :)
It's ok.. after all.. our cars are IDENTICAL... right? :P
WTF!!!
Is wrong with the forums!!!!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
