  • Replies 85
BTW, this is gonna sound weird, but: the 3 skylines I've test driven now, they all seemed to have huge backward and forward body roll on take offs. I drive a civic which (to me) feels like it's on rails (ignoring the understeer), but these skylines felt rather doughy and uninvolved by comparison simply cos of the roll.  Is this just because A) I'm not pushing the test cars cos I don't wanna get my ass kicked) and B) I'm just used to a small buzz box now that doesn't have enough power to even break traction from a standing start or push me into my seat?
Sounds like they have standard suspension in them, which is probably worn. They handle like boat anchors with standard suspension...
nah, its not the suspension, its because it has so much power, that it just throws you back and the car is wheel standing!!!! (yeah right....i wish!)
yeah, the standard suspension is a little on the saggy side. you can buy my suspension off me if you want? (its not stock...). i've just bought some coilovers..... :P hehe
Edited by Frink
I don't like the look of the R32s
i am with you well sorta its not that i dont like them but i prefer the 33 i could have got a 32 gtr but they just dont appeal to me as much as a 33... though i am getting a bit of a 34 bug at the moment i really want one pity their is 0% chance of that happening
Yeah sounds like your on the money with what your looking for!
Dont listen to half these 32 drivers on here! There still stuck with there 2lt commodore engines at the end of the day. (not you GTR boys!)
I'm not sure what your talking about with the "roll" on take off but my advice would be too sit in the passenger seat of mine and i'll give you a demo takeoff from about 6000rpm.
If you have any questions about SII R33's then i'll be happy to fumble out an answer.
theres nothing wrong with 32'! lighter than 33's and looks sportier etc... ask veilside, he'll tell you that 32's are better (i hope!) and he used to own a 33. but if your happy with a 33 then thats kool too, do what you want not what other want you to do :D
I'll try to get to the next friday night meet, and take you up on that offer! :D
I think I've made a subconscious (sp?) decision to upgrade the suspension on the skyline I get (if needed) before doing any stereo work. And that's saying something considering I spent 1600 on the sound in my titchy little civic hahahahaha
ok now i just read this thread it turned into a 32 vs 33 slander feast.
So Stirlo like steve said come sit in the passanger seat of my 33 see how quick you go white like me.
As for weight diff mines 1260kg so whats a 32 hmmm
nice to see we r all staying on topic.
just quickly, yes i prefer 32's but that said, i still loved my 33 (much roomier and very sexy)
anyway back on topic lads, there have been a million which is better threads and its purely personal preference, but so you all know....they are all better than peice of sh*t diahatsu's!
There's a white Skyline down the street from me but I don't know them.. it's a Northside suburb with a lot of old folks homes. If u read this and it's u, maybe I could walk down the street and check it out?
^^^ copyed from first post
If its a white one with no rear spoiler (stealth one) 18s (volks) fmic that would be me come up any time during the week only late in the arvo but.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
